I bought a set of front/rear Lloyd floor mats and this is what I got
Subscribe
Jul 5, 2015 | 09:09 PM
Front ones are fine
Rear ones are totally different in size and shape
One is 2 inches larger than the other one
What do you guys think? Is this your experience with Lloyd Mats? I bought them because they were american made and was expecting a good finished product
Reply 0
Jul 5, 2015 | 10:13 PM
Re: I bought a set of front/rear Lloyd floor mats and this is what I got
There must be a reason for the difference.Thats the part that tucks under the front seat.Mine are the same way & I bought mine some ten years ago.They are the classic ind mats, but same quality/features.
I also noticed the front mats didn't exactly match the OE either.Never bothered me enough to dig further.
Reply 0
Jul 7, 2015 | 12:52 PM
Mine look like that as well. I just figured the passenger side was a little wider because you were more likely to have someone in the back seat behind the passenger rather than the driver. It could also be the way the front seat sit compared to the trans tunnel and the outer rails. Both a re purely speculation.
I say put them in. You'll forget they're different shapes.
Reply 0
Jul 7, 2015 | 01:02 PM
Quote: Mine look like that as well. I just figured the passenger side was a little wider because you were more likely to have someone in the back seat behind the passenger rather than the driver. It could also be the way the front seat sit compared to the trans tunnel and the outer rails. Both a re purely speculation.
I got the answer from the factory.
The shapes and sizes are correct.
The big one goes behind the driver seat, the small one is for the passenger.
Unfortunately they do not include pictures or a description of this, so unless you contact Lloyd, you don't get this information
Hope this helps
Reply 0
Jul 7, 2015 | 02:55 PM
Probably to do with that one seat bolt that faces in, on the pass side.
Reply 0
Jul 7, 2015 | 06:57 PM
Nice! How do they look in the car? Do they fit the contours of the floor?
Reply 0
Subscribe
