heat inside car
Old Jul 17, 2015 | 07:46 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
heat inside car
has anyone ever done anything to the interior to make it cooler? i get lots of heat out of my car from the shifter area and the firewall dash area, i love the car but i hate driving it because of this.
Old Jul 17, 2015 | 09:05 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: heat inside car
Buy some dynomat or similar material and find where the heat is coming through and pad it. Is it auto or manual? Never mind I see tremec in the side bar, make sure that any seals around the shifter under the console are torn or loose.
Old Jul 17, 2015 | 09:32 AM
Z-28's Avatar
Car: 1986 Z 28
Re: heat inside car
I would definitely check for bad seals all around . I had a heat issue on my passenger side and it turned out i had a leak right at the cat .
Old Jul 17, 2015 | 11:03 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: heat inside car
Good carpet and floor mats made a huge difference in my car.
Old Jul 20, 2015 | 07:48 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: heat inside car
Its because your getting the heat bleed-off from the heater core.
Easiest way is to disconnect the heater core or install a shut off
valve in the heater core line.
Old Jul 20, 2015 | 07:59 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Re: heat inside car
i don't think it's that, but i'll install a cutoff and see..
Old Jul 21, 2015 | 01:22 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: heat inside car
i put a rear window louver on mine and T top sun shades. that dropped the interior heat considerably. my heat issues are solar though.
Old Jul 21, 2015 | 01:52 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: heat inside car
Open the window more or drive faster!! lol
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Kaweh
Aug 9, 2015 02:54 PM
z28addict8490
Aug 7, 2015 08:48 PM
