Hey, I've been looking for a replacement gauge cluster for my 83 Z28. My speedometer and oil pressure gauge are no good, and i think my tachometer is on the way out as well. Individual gauges I've found have been a bit expensive. So I found a refurbished gauge cluster on hawks third gen parts. The entire gauge cluster with the 145MPH speedometer, entirely tested and gone through. $400. I know i can get cheaper used parts but i figured with this i know what i'm getting... You guys think this is a good deal?
I think you need to do some testing and make sure it's the cluster and not sensors and cables before you drop 400 and still have to replace other this possibly.
JamesC
close
$400 seems excessive to me, but each to his own...
Electrical issues can crop up when swapping clusters, so you might consider perusing the following link:
https://www.thirdgen.org/forums/inte...atability.html
The speedo cable is likely the culprit:
https://www.thirdgen.org/forums/inte...eedo-woes.html
Check sensors. The car is after all 30+ years old.
JamesC
JamesC
