Clutch
Old Nov 17, 2015 | 10:18 PM
1982firebird7's Avatar
Car: 1982 Pontiac Firebird
Engine: 2.8L V6(upcoming 350 Swap)
Transmission: "World Class" T5
Clutch
Hey i was just wondering how to tighten my clutch pedal.
Old Dec 4, 2015 | 12:04 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Clutch
Unless you've purchased an aftermarket clutch master cylinder, they're not adjustable. Chances are that if the pedal doesn't feel right, you need a new clutch master cylinder and/or slave cylinder.
Old Dec 5, 2015 | 04:56 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Clutch
If it's original 82 it has a cable actuated clutch which probably is adjustable.
But, you posted in the interior section so no one saw it.
Post and research in the tranny section and you will find the answer.
Old Dec 8, 2015 | 09:08 PM
Re: Clutch
well not like adjusting as in pulling it out or pushing it in. im talking about, the clutch pedal likes to move side to side. i was just wondering how to fix that problem
Old Dec 9, 2015 | 08:24 AM
stealtht/a's Avatar
Re: Clutch
It's mounted on a rod that also has the brake pedal on it.
Take a look up under the dash and see if it's missing some bushings or maybe it's a tacked on manual conversion. You should be able to see the problem.
Piston454
Nov 24, 2015 06:49 PM
92rszz4
Nov 23, 2015 03:59 AM
Galaxie500XL
Oct 30, 2015 08:24 PM
Galaxie500XL
Oct 27, 2015 10:58 AM
dibella989
Oct 21, 2015 07:53 PM
