Hatch Latch Motor Elimination?
Old Dec 14, 2015 | 11:55 AM
FranktheTank86's Avatar
My hatch latch motor is shot, it will not go down all the way and clicks. And it looks trashed and I don't want to spend money to fix it or replace it IF: Can I just get a latch from a non motorized Camaro for 15 bucks and mount that to the body. Are there holes there for a standard latch?
Old Dec 15, 2015 | 12:46 PM
Re: Hatch Latch Motor Elimination?
No one has ever done this?
Old Dec 15, 2015 | 05:28 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Different mount for the standard (non-pulldown) latch on 82-84 models, it has been done but you need to fab the mounting bracket.
Old Dec 22, 2015 | 08:52 AM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
You dont have to buy anything. You can just pull the motor and stuff out and convert the existing latch to work without the motor. You just have to make sure the receiving latch is in the proper position to close the hatch. Clamp it in this position then drill a couple of holes and bolt it down. It has been awhile since I did this but I think once you pull off the plastic trim and stuff it was obvious what to do.I did this to my sons 88 TA works just fine and you cant tell once the plastic trim is put back on.
Old Dec 22, 2015 | 10:58 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Mine was done like that when I bought it.....
dragonmas
Dec 26, 2015 08:49 AM
gnilson
Dec 16, 2015 03:17 PM
yessahbud
Dec 6, 2015 02:56 PM
dragonmas
Dec 5, 2015 10:11 AM
Galaxie500XL
Nov 24, 2015 02:12 PM
