hvac help - blower fan doesnt come on
Old Mar 7, 2016 | 10:41 AM
robpp's Avatar
Car: 89 IROC Convertible
Engine: 383
Axle/Gears: 373 strange axles
hi
been trying to figure this out with the service manual
89 iroc.
fan came on last week. noticed the other day it wasnt coming on in any position.
checked 25 amp fuse = GOOD.
next book says NO BLOWER to do voltage check at motor.
says put on VENT then fan on HI and check voltage at fan motor. should be battery voltage but nothing there.
says next with no blower to check hvac controls in dash. 12v IN is brown wire = 12v GOOD.
it then talks about the brown with White wire. any pos but off should have 12 v and YES that is good too.
tells me to check wires going into Hi Speed resistor.......all voltage checked good.
gave up last night,
for giggles this morning I did get my power supply down and put 12v to the blower motor and it does work.
today i plan to test the switch but from the symptoms and result according to the manual I cannot find an issue.
one more thing.
manual says test motor with switch on HI and I dont get voltage...;.
BUT if I put the switch on OTHER positions not high I DO get some voltage to the motor but it was like 11.89 on my meter.
ANY IDEAS
AND if I do need a head unit or a switch is aftermarket my only choice?
Old Mar 7, 2016 | 11:22 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: hvac help - blower fan doesnt come on
Hi speed relay.Did you check it? Its by the blower fan.
Old Mar 7, 2016 | 11:39 AM
robpp's Avatar
Engine: 383
i havent tested that just yet.
but I will later today.
Old Mar 8, 2016 | 08:10 PM
robpp's Avatar
Engine: 383
Looks like it was the relay based on testing.
I ordered one from prime. I wanted the AC delco one.
Will finalize once installed and tested.
utfan01ss
Mar 13, 2016 12:58 PM
Relik
Car Audio
Mar 11, 2016 02:26 PM
anesthes
Mar 9, 2016 09:36 PM
LsxMatt
Interior Parts Wanted
Feb 25, 2016 12:39 AM
mcgarnicle
Exterior Parts for Sale
Feb 17, 2016 04:02 PM
