Are all 3rd gen fbodys the same windows?
Old Mar 11, 2016 | 02:28 AM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
Ever since I've owned my iroc (17 years), I have had to roll the passengers side window down a little to close the door otherwise it catches on the t top rubber lip. Could it be the window is from a firebird or something else, that would sort of fit but not be the same?
Old Mar 11, 2016 | 07:29 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Are all 3rd gen fbodys the same windows?
They're all the same. I don't have this problem on my Trans Am, and the driver window and door are from an '89, the T-Tops are from other years.
Old Mar 11, 2016 | 08:29 AM
82tarecaro's Avatar
You need to adjust the window. There are adjustments to the angle the window sits in the door and the maximum height the window will go up. If you play with those a bit you should be able to fix that.
Old Mar 11, 2016 | 07:09 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Originally Posted by 87iroctheo
...I have had to roll the passengers side window down a little to close the door otherwise it catches on the t top rubber lip.
My T/A does the same thing, but it's because the t-top drip edge is pulling out of the t-top itself...not an uncommon failing.
Old Mar 26, 2016 | 10:53 AM
Firebat's Avatar
Ditto. Adjustments. I had a window issue on my 92 t-top for 10 years but fixed it a week before I sold it to make it easier to sell. Just take some time and try to make some adjustments.
Old Mar 26, 2016 | 10:56 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
X3 all the windows are the same.
TransamGTA350
Camaros Wanted
Mar 22, 2016 05:26 PM
siuol
Mar 7, 2016 04:55 PM
Shane87irocz
Exterior Parts for Sale
Mar 7, 2016 08:01 AM
jster1963
Mar 6, 2016 05:43 PM
joef2002
Mar 5, 2016 08:26 AM
