Console wiring
Old Mar 12, 2016 | 03:59 PM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
Console wiring
So I'm trying to reassemble the interior in my project '90 T/A. I bought the car in a partial state of dis-assembly, so now that the paint is done, I am trying figure out what goes where. I have a tray full of small parts and fasteners and as I was putting the console back together, I found a couple of anomalies in the wiring. I can't find a plug for the storage compartment light, but I found 2 wires with pins on the end that might be intended for that. I also found a gray plastic thing-a-ma-jig with a bunch of wires plugged into it. I have attached a picture of same.
If, in fact, the 2 loose wires belong in a plug-like device that would then allow the storage compartment light to function, where the heck can I get one?
What does the gray device do and is it supposed to plug into something or does it just float freely in the deep dark recesses of the console?
TIA
Geoff
Old Mar 12, 2016 | 06:31 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Console wiring
That gray plug is for the power mirror controls.
Old Mar 12, 2016 | 09:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Console wiring
The 2 wires(Orange and Black) goes to this Light Switch.
Old Mar 13, 2016 | 08:48 AM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
Re: Console wiring
This is what the gray one plugs in to .
http://www.ebay.com/itm/like/351660614322?lpid=82&chn=ps&ul_noapp=true
Old Mar 13, 2016 | 10:57 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Console wiring
Confirm the plug definitions. Assuming the vehicle does have power
mirrors (controlled by a single switch), & power windows (with a
dedicated switch for each window) the connections are pretty
self-correcting. While possible to reverse the right & left window
connections, if memory serves correctly, the main harness comes in
from the driver side, and the passenger window switch has slightly
longer wires.
If you have/can acquire a compartment light, those pins should
easily re-install. You might have to carefully bend open the
retaining tabs a bit.
In general, orange wires are constant power, and black is ground.
Good luck, & keep us posted.
Ikes 91Z
Mar 23, 2016 07:01 AM
MantyZ28
Mar 16, 2016 05:21 PM
L98GTA87
Feb 29, 2016 08:51 AM
AdarianZ28/IROC
Feb 29, 2016 01:28 AM
Boxxx
Firebirds Wanted
Feb 26, 2016 10:36 PM
