[FL] Bunch of parts
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Bunch of parts
Getting rid of a bunch of parts. Sold my car and want this stuff gone. Will be listed locally as well since I'm just trying to move it. See something you need throw me a number.
Aluminum spare tire with tire saver (tire will need replaced)
GTA washer resivour
Brand new c-maxx brake brads for front-SOLD
Oil pan with rails
Newer harmonic balancer with bolts
Used l98 roller lifters and push rods
Autozone 700-r4 shifter cable (works but needs a metal clip on the end where it attaches to the transmission side, never gave me any problems
TPI engine bay fuel lines
Rear hatch area MANUAL cover in black
Auto shifter assembly (**** needs recovered or just replace it)
Newer autozone timing cover assembly (no timing tab)
Oil filter protector and adapter for removing
Black front kick panels
L98 autozone reman starter, works great
TPI early throttle body (needs rebuilt, has shaft play)-SOLD
700-r4 torque arm mount
Stock T-5 shifter
Headlights, buckets with mounting brackets (one bucket has a small crack)-Driver side SOLD
GTA grey arm rest (will have to confirm which side it's for)
GTA driver seat rail-SOLD
Early TPI style air cleaner assembly ( the ducting has some tears from where the AC compressor rubbed it, some kind of sealer could seal it up I'm sure)-SOLD
91 Camaro cover that goes under the steering wheel
GTA washer resivour
Oil pan with rails
Stock T-5 shifter
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Bunch of parts
does the spare have the inflator bottle or do you have the inflator bottle?
Car: 1987 Trans am
Car: 1987 Trans am
Re: Bunch of parts
Brake pads, throttle body, driver headlight bucket, and tpi intake is sold
Transmission: Pro-built 700R4
Re: Bunch of parts
Can I get a better picture of the windshield washer fluid bottle?
Car: 1987 Trans am
SUPER CHEVY66
22
Mar 6, 2016 01:29 PM
'91CamaroRS
Jan 22, 2016 11:48 AM
