What to clean throttle body with?
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I'm rebuilding my throttle body. I've taken everything apart already,and it's covered in gas from leaking injectors,grease,dirt,and carbon. A couple of the old gaskets are also stuck on. I know I'll be doing some scraping for that,but I want to soak the parts in something to clean them up,and make it easier to get the gaskets off. I've heard lacquer thinner is one thing. Will this hurt the throttle body or hurt plastic?
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: What to clean throttle body with?
Go to your local parts store and pick up a bucket of Berryman carb cleaner. Soak it in that for a day or two and then spray it down with brake or carb cleaner.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
i like this stuff, but that doesnt help if you want to soak it
Eff a bunch of that.
Go to yer local hardware or home improvement store and pick up a gallon of lacquer thinner. You'll only use a fraction of it, and you'll find it's THE BEST parts cleaner you have EVAH come across.
You'll also find, the gaskets come RIGHT OFF; no need to be scared of those.
Use dielectric (spark plug boot) greeeeeeze on the 0-rings and such when putting it back together.
sleprock
Jan 28, 2016 09:54 AM
