1987 Z28 Idle/Gas issue
Old Jan 7, 2016 | 12:48 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Hello guys, im having an issue with my z28 in which it will start and idle for about 5-10 seconds then it stumbles and dies. While its idling if i press on the throttle it chokes and dies as soon as I do. I have changed the fuel filter and fuel pump, checked the tps and iac, and cant seem to notice any vacuum leaks. No codes are being thrown. Any ideas?
Re: 1987 Z28 Idle/Gas issue
Also did check fuel pressure, with key on its about 45psi and stays steady once i start the car, does not drop.
Old Jan 7, 2016 | 03:23 PM
And if i spray starter fluid the car will idle for longer im guessing as is finished off the fuel. Im guessing this would rule it a fuel problem
Old Jan 8, 2016 | 10:55 AM
Checked the plugs last night and they are badly fouled and black, might this cause the engine to stall and not hold an idle?
Old Jan 8, 2016 | 02:38 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Wouldn't hurt to clean them or get new ones depending on how old they are. Even if it isn't the issue, it's definitely not going to hurt anything.
Old Jan 8, 2016 | 05:20 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
How are your injectors?
Old Jan 13, 2016 | 11:37 AM
I haven't checked them as of yet, how would I go about checking them? Also I notice the oil pressure drops as the car stumbles and dies. Might the oil pressure sending unit cause such issue?
Old Jan 13, 2016 | 11:56 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
As the car stumbles and dies, the RPM's are less which in turn causes it to lose oil pressure.
Normal.
Check for vacuum leaks. You mention IAC/TPS is fine, may have a vacuum leak, plug wires, timing issue, cap/rotor...
Old Jan 13, 2016 | 12:23 PM
Normal.
Need to get a diagram for the vacuum lines. Did the plugs and wires, cap seems to be in fair condition. I will check the rotor, and the timing. What should the timing be set at?
Old Jan 13, 2016 | 12:42 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Timing is 6* BTDC
see this
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Jan 13, 2016 | 12:44 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
...LB9
Old Jan 13, 2016 | 01:04 PM
...LB9
Thanks a bunch! I also need to check the cap and rotor havent replaced those since roughly two years give or take!
84 1LE
Dec 20, 2015 09:12 PM
apie2546
Dec 18, 2015 11:21 AM
86LG4Bird
Dec 15, 2015 07:16 AM
defaria27
Dec 13, 2015 12:06 PM
Galaxie500XL
Dec 11, 2015 08:34 PM
