how to rebuild a rear diff
Old Jan 7, 2016 | 07:47 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
im looking to rebuild my 9 bolt but would like to learn how to do it myself I am quite familiar with it somewhat im looking at installing 3.70's as well but was wondering what kind of parts do I need for the rebuild do I just need a new ring and pinion or is there a lot more involved ????? ive pulled whole carriers out before but never installed them or rebuilt them that was always for the more experienced mechanic's in the shops.
Old Jan 15, 2016 | 09:09 AM
lt500r55's Avatar
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
Re: how to rebuild a rear diff
I've got 1 apart right now an trying to shim the cones/spider gears with a 2.5 in OD shims and they are not as readily available as other sizes go figure. maybe some help here would help us both. Dan
Old Jan 15, 2016 | 11:20 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Search search. Loads of threads on this including all the parts you'll need. There is a really detailed document on-line somewhere with pictures and instructions. Takes a lot of reading and care to get it right if you haven't done it before. Getting the gear pattern is critical. Have fun.
Old Jan 15, 2016 | 12:10 PM
lt500r55's Avatar
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
found these for the shim in between cone an spider gear. 62mm= 2.44094 in. close enough for me. if you are going to tackle that part.
Amazon.com: C1074/C1095 Spring Steel Round Shim, Unpolished (Mill) Finish, Spring Temper, ASTM A684, 0.3mm Thickness, 50mm ID, 62mm OD (Pack of 5): Industrial & Scientific Amazon.com: C1074/C1095 Spring Steel Round Shim, Unpolished (Mill) Finish, Spring Temper, ASTM A684, 0.3mm Thickness, 50mm ID, 62mm OD (Pack of 5): Industrial & Scientific
B4C5.7
Mar 6, 2016 05:23 PM
gta_knight
Jan 26, 2016 12:29 PM
1701-Z
South East Region
Jan 11, 2016 08:36 AM
'91CamaroRS
Jan 10, 2016 10:28 AM
no green
Jan 4, 2016 08:11 AM
