Seat belt light
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Seat belt light
Hi,
The seat belt light in my car stay on more than the "8 seconds" when it suppose to go off. Every now and then, it will shut off while driving, but rarely happens. The service manual says that the light only ( not the buzzer) is control by the ignition switch and the timer. Does any of you have the same problem? Or have a suggestion in how I might fix this? Where the timer might be?
Any help is appreciated!
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Seat belt light
It should go out when you clip on the seat belt & stay off, unless you unbuckle it.I think it stays on for a few seconds when you start the car, then the light & buzzer shut off, 6 sec sounds about right.
xbazzarex
Feb 20, 2016 09:08 PM
