Best Way to Protect Dash Pad??
hi - dash pad on my new to me 89 TA is perfect-been garaged...I plan to drive this car, but still garage it. What is best way in your opinion to protect the dash pad from splitting.cracking?? I see various "covers" from cloth to plastic...any worth considering? or, proper care with quality lubricants like Mothers/Maquires, etc better approach?
Thx!
Thx!
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Best Way to Protect Dash Pad??
a product with UV protection and no exposure to cold temperatures
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I'd put a cover over it if it's sitting in the sun, and I would not drive it over uneven ground on cold winter days.
Car: 1991 Firebird
Engine: 3.1L V6
Remove it as few times as possible. If you have to remove it to get to something, might as well do all you can under it while it is off. When installing it back, DO NOT OVER TIGHTEN screws and bolts. In fact, hand tighten only if possible, don't use a ratchet.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Even with a cover I wrapped the corners with black felt. I loosened the screws on the corners enough to make a nice fold and pushed the corners of the felt in there. Actually came out pretty nice.
My car has been my DD for 10 years now and the pad is still pristine.
The weather here is not extreme though.
You can see were the corners are wrapped in the bottom two photos.
dennisbernal91z
Apr 14, 2016 05:42 AM
whitedevilTA
Mar 11, 2016 01:19 AM
