Ok so I originally had the old 85mph gauge in my car and was looking to swap it over to the 145mph gauge with the rpm gauge and the needles rather than lights for the oil, battery, and temperature. I am unsure whether or not I can just plug this new one in or not. Today I removed my old cluster and put in the 145 mph gauge but for some reason, when I turned my key the fuel gauge as well as the temp gauge and a couple others didn't move at all. Do I have to convert something? Did I get a bad cluster? Also one of the blinker lights doesn't turn off, even when my lights are off. Thanks in advance!
midias
close
So what kind of car do you have?
Sorry lol. 1987 Camaro v6 (will be v8 soon)
Quote:
Originally Posted by midias
So what kind of car do you have? You may have to. I have an 85 and converted to the 145mph cluster from a later 80's car. I had to rearrange some of the pins on those two connectors behind the cluster. You need to get the wiring diagram for your car and the one the gauges came from to figure it out.
JamesC
close
Quote:
Sounds like original dummy lights. If so, the following should put you on the right track:Originally Posted by ama2212
Ok so I originally had the old 85mph gauge in my car and was looking to swap it over to the 145mph gauge with the rpm gauge and the needles rather than lights for the oil, battery, and temperature. https://www.thirdgen.org/gauges/
JamesC
Quote:
Originally Posted by tojan19
You may have to. I have an 85 and converted to the 145mph cluster from a later 80's car. I had to rearrange some of the pins on those two connectors behind the cluster. You need to get the wiring diagram for your car and the one the gauges came from to figure it out. Quote:
JamesC
thanks guys!! ill check out the wiringOriginally Posted by JamesC
Sounds like original dummy lights. If so, the following should put you on the right track:https://www.thirdgen.org/gauges/
JamesC
John in RI
close
- Join DateAug 1999
- LocationRI
- iTrader Positive Feedback100
- iTrader Feedback Score(170)
- Car1984 Camaro Berlinetta
- EngineLT1
- TransmissionT56 6-speed
- Axle/Gears4.11 LS1 Rear End
- Liked:465 Times in 359 Posts
FYI: Not all gauge clusters are the same. The 'plug & play" compatibility range is 82-85 and then 86 to 89.
From the link James posted for you :
Quote:
IMPORTANT: You have to follow directions below. If you don’t replace your sending units, bad things could happen.
I don’t know what because I did my swap the right way. Maybe nothing, maybe something. Do you love your camaro? Don’t risk it, read on.
You will need to replace the oil pressure Sending unit and the water temperature sending Unit.
A Haynes Manual Can help you finding and replacing them. Just get them from the auto Parts store and make sure they are made for GAUGES, NOT DUMMY LIGHTS. Yeah, those cool red ones at the top you hope you never see again. Done?
Quote:
John, what is required to do to install the 86-89 gauges into a pre 86?Originally Posted by John in RI
FYI: Not all gauge clusters are the same. The 'plug & play" compatibility range is 82-85 and then 86 to 89. I was planning to get rid of the 85 mph setup.
*edit* I found one of your posts mentioning a backlight and brake light need to be reconfigured.
John in RI
close
- Join DateAug 1999
- LocationRI
- EngineLT1
Yup, That's the problem.
The BRAKE warning light was moved from the far Right to the far left of the cluster. if an 86+ cluster is used in a 85 and earlier car then this change will cause 1 or 2 of the backlights to become non-functional as well as the BRAKE warning light.
All other functions should work normally.
I'm not sure re-pinning the cluster will resolve this problem or not. The simplest way to overcome it ( IMO ) is to use a 82-84 gauge cluster and install the 86+ 145 Speed head into it. The 82-85 cluster ( more accurately - it's printed circuit ) will be a direct match for the 82-85 dash wiring.
That would work but the trip meter reset is in a different location.
John in RI
close
- Join DateAug 1999
- LocationRI
- EngineLT1
I figured that you swapped full clusters already because the other gauges ( not speed ) started giving you trouble. During a direct idiot light-to-gauges cluster swap the fuel and tach should work fine,... but the temp and OP gauges need new sending units before they will work properly
What you say is true; again, I thought you already had a full 86+ cluster. So,....... to be more accurate; Just swap the Speedo head and matching clear lens into an earlier 82-85 (GAUGES) cluster to avoid compatibility problem.
