Seat Mounts
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Seat Mounts
Anyone ever come up with a fix for this problem other than replacing the floor pan or grinding down and welding a new stud?
Bolts coming up from the rib attached to the floor pan have rusted and snapped off when removing the nut that holds down the seat. In red circles.
Axle/Gears: 3.45, 3.27, 3.27
Re: Seat Mounts
I know it is crude, but the previous owner of my Firebird drilled a hole through the floorboard and installed one of the seat rails with a long bolt and washer from below.
Lon
Lon
Car: 1984 camaro z28
Engine: gm 350(still to confirm)
Transmission: borg warner 5-speed
Re: Seat Mounts
This has recently happened to me. I'm looking to repace the brace/mount but have no luck get sourcing one. GL
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Seat Mounts
It appears that your floor is in pretty good shape, I would tack weld new studs down.
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
BobKnake
Apr 21, 2016 02:31 PM
