Hatch won't close completely
Old May 21, 2016 | 10:59 AM
KingHD's Avatar
Car: 1987 Camaro
Engine: 350 HO 360whp
Transmission: Borg-Warner T5
I replaced the pull down motor it works great it goes up and down fine. The thing is it won't close the trunk all the way so that its flush. When i close the trunk itll pull down and wont finish the process I'll hear a loud sound sorta like a jackhammer but it just won't close completely. I have to hear the damn thing squeak while driving down the road.
Any advice or a simple fix would be appreciated.
Car: 87 Camaro Lt
Pictures of the wiring
Old May 21, 2016 | 01:21 PM
Steve86TA's Avatar
Car: To many to list
Re: Hatch won't close completely
Have you tried to lower the assembly a little? If that does not work, it sounds like the gear may be starting to strip.
Old May 21, 2016 | 01:31 PM
KingHD's Avatar
Car: 1987 Camaro
Yea ive messed with it like that just can't get it to close like I want it without it squeaking while I'm driving and if I hit a bump it'll squeak very annoying Lol. Could you give me an idea on what to look at? I was thinking the tracks on the sides need greased.
Old May 22, 2016 | 10:11 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
pull the assembly out and pull the motor and gear box apart. There is a threaded collar with teeth on it that the motor drivers that moves a threaded shaft up and down. Most likely that collar is stripped. Its plastic.
HerpDerp1919
Jun 18, 2021 01:03 AM
Doug Phillips
Sep 23, 2016 09:25 PM
notrabies
Jul 29, 2016 09:39 PM
90Camaro5speed
Apr 2, 2016 02:41 PM
mclenty0
Mar 19, 2016 11:36 AM
