Hatch Pulldown Motor Question
Old May 22, 2016 | 09:14 AM
Trelane's Avatar
Car: 1991 Pontiac Firebird 3.1 V6
Hi,
I have a 1991 Pontiac Firebird.
We have tested the rear motor manually and it working. We had a blown 15Amp fuse and have replaced this, and now when we are getting a 'click' in the relay when we depress the black plastic leaver. However the mechanism is not moving up/down.
Also when trying to close the lid the strange metal bolt highlighted prevents the boot from closing. What is the function of this 'spring'? Why is it closed blocking the boot from closing? How do i get it to 'reset' or go up?
Any help would be really appreciated,
Mike
Old May 22, 2016 | 11:07 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Hatch Pulldown Motor Question
not sure what the metal thing is, but make sure your latch is adjusted correctly. If it is not in proper position, your hatch will not close. The latch will slide forward and backwards, toward front and back of car. Make sure its centered so everything lines up.
Old May 22, 2016 | 10:08 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Never seen that style
the breeze
May 22, 2016 06:30 PM
ratinfested
May 1, 2016 07:53 AM
the breeze
Apr 1, 2016 06:20 AM
Kylej68
Mar 31, 2016 05:40 PM
Matthew1
Mar 18, 2016 02:40 PM
