kick panel lights
Old Jun 15, 2016 | 03:07 PM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
kick panel lights
My car is a 91Z that didn't come with the front lower kick panel lights that turn on when the door is opened but i've got them out of a car from the JY and going to install them. Where is the best place to tap/splice into the lighting harness for them to work properly?
Old Jun 15, 2016 | 05:41 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: kick panel lights
I would think off of the door jamb switch, but I don't know if they would come on when you turned the interior lights on with the headlight switch.
Old Jun 16, 2016 | 07:21 AM
That was my thoughts exactly. I suppose I'll just have to break out my digital multi-meter and check it out this weekend. After I get them installed and working properly, I plan on doing the LED conversion throughout the interior.
Old Jun 26, 2016 | 09:00 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
if you tap into the courtesy light wiring than the floor lights will become active any time the dome light is active. Those wires lead behind the drivers kick panel and up the drivers side "A" pillar so they are easy to get at and in a good spot to tap the floor light wiring into.
Veaceonee
Nov 9, 2019 10:52 AM
Michael Harding
Jan 12, 2019 11:11 PM
dennisbernal91z
Apr 14, 2016 05:42 AM
stegal
Apr 2, 2016 10:43 PM
Gecz28
Mar 26, 2016 04:07 PM
