Where does this go
Old Aug 9, 2016 | 03:47 PM
LDR's Avatar
LDR
Car: 2012 Impala ltz 1988 Gta project
Where does this go
I'm trying to piece together a car. Been years since I worked on a third gen. To save time looking through pics after pics where does this harness go to.
Old Aug 9, 2016 | 03:52 PM
Steve86TA's Avatar
Car: To many to list
Re: Where does this go
They are for the power lumbar seat
Old Aug 9, 2016 | 04:04 PM
LDR's Avatar
LDR
Thank u. Cars mostly gutted and I'm finishing pulling what Evers not essential
Old Sep 9, 2016 | 07:48 PM
LDR's Avatar
LDR
Ok here I go again. Kinda hard to see in. This pic but it's a small black plug yellow wires with a black sheeth. Comes out of steering column. Last plug on my rewire and I can't figure it out
Old Sep 9, 2016 | 10:36 PM
Vassago's Avatar
Car: 1989 IROC-Z Vert
Engine: 305 TPI (LB9)
Transmission: 700R4 Auto
Looks like the VATS wires to me. Coming from Ignition switch.
Old Sep 9, 2016 | 10:44 PM
Vassago's Avatar
The other wires the black plug connects to, one of them is a purple wire if I can remember correctly. I know on the 89 model the wires are yellow for vats and 91-92 models the wires are white that run through the steering column to the ignition. Very thin and delicate wires, especially at the ignition switch. they usually break at the ignition over time from the constant turning of the ignition switch.
Old Sep 9, 2016 | 10:51 PM
Vassago's Avatar
Very essential wires unless you want to bypass the module or something like that. which I wouldn't unless you absolutely have to.
Old Sep 9, 2016 | 11:18 PM
LDR's Avatar
LDR
Ok cool so in my situation it's useless. Car is gutted there's no pcm or vats around. I agree I wouldn't disable it if I had all the parts. Being this car was stripped this is one thing I won't add back.
Old Sep 9, 2016 | 11:57 PM
Vassago's Avatar
Good deal! Best of luck on the build man. Are you going to do a thread of the rebuild? What year and model is she? What are your plans for the engine or paint?
Old Sep 10, 2016 | 12:43 AM
LDR's Avatar
LDR
it was an 88 gta. somewhere along its life it became a parts car and was stripped. I am rebuilding it. got a cheap 454 im gonna build for it. Then where painting it a flat purple with graphire accents.
Build thread i would but its been work then abou 3hours of car rinse lather repeat.
Old Sep 10, 2016 | 02:34 AM
Vassago's Avatar
I'm glad to see another third gen getting saved instead of getting scrapped. Good to hear. 454 is gonna be nice. Good luck!
Old Sep 15, 2016 | 07:22 PM
LDR's Avatar
LDR
Ok I really wish I could find the factory manual with wiring. I figured most of the turn signal switch out but these 4 I can't figure out
BLITZ-88Z
Jul 10, 2018 09:24 AM
Matthew1821
May 24, 2016 05:33 PM
mcgarnicle
May 21, 2016 04:57 PM
badlefthand
May 17, 2016 11:33 AM
dad24doys
May 16, 2016 07:34 AM
