Stainless Steel Door Strikers
Old Sep 15, 2016 | 12:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Got these after I decided my originals were just too worn out (egged).I didn't think it would clean up the appearance that much, but quite surprised how much it did.Also put a 1/4 s.s spacer in place of two of the big washers.
Old Sep 15, 2016 | 03:07 PM
WTR388's Avatar
Car: 87 Trans Am
Re: Stainless Steel Door Strikers
Well, I guess I know what I'm going to make if I get some free time on the lathe at work... Think aluminum would hold up?
Old Sep 15, 2016 | 03:23 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Did you get those off eBay? I got a set recently and the quality looks real nice. Price wasn't bad either.
Old Sep 15, 2016 | 03:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Some argue if the s.s is as hard as the OE pieces, but I definitely feel aluminum would bend to easy.
Yep, got them on good ol eBay.
Old Sep 15, 2016 | 05:46 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
If you do, any possibility of a S.S. set? Maybe try and compete with Hawks?
http://www.hawksmotorsports.com/door...strikers-pair/
Always wondered what the actual issue was with S.S. strikers durability over OEM. Just don't slam the doors and they should hold up fine. My doors close better than some of my friends newer rides so I would like a set just to test if anything lol.
Looks good either way man. Thanks for the spacer additive. Good stuff.
Old Sep 15, 2016 | 08:54 PM
battmann's Avatar
I want to say mine were like $30 shipped from eBay.
Old Sep 15, 2016 | 09:18 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I think they're more than strong enough.Newer cars have very thin strikers, could the steel be much better than our originals?Thankfully, my doors close with just a modest effort, even with the windows all the way up.
I want to say mine were like $30 shipped from eBay..
Same here.
Old Sep 16, 2016 | 08:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Same here.
Our cars use the doors as a body brace though, that's one of the reasons the doors are so heavy. Once latched the door links the A pillar to the B pillar so it would necessitate a strong striker. Newer cars are using the doors only as a way for ingress and egress.
Old Sep 16, 2016 | 09:49 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Definitely. It has nothing to do with slamming the door to bed the striker, it is under constant force while you drive it
1992 Trans Am
Aug 19, 2016 01:32 PM
jbenge
Members Camaros
20
Apr 6, 2013 08:06 PM
RPM WOT L 98
Aug 19, 2008 03:09 PM
Birdman916
Jun 14, 2007 04:38 AM
Trace Cook
Aug 8, 2003 07:40 AM
