Replaced this bulb don't know where it goes😭
Old Aug 10, 2016 | 06:55 PM
Eli Delgado's Avatar
Car: 1992 Camaro Rally Sport
Engine: "Stock"
Transmission: 5 Speed T5 WC
So im new to actually posting just got a 92 RS 5.0 and am semi restoring the beauty. I bought it and did the calipers,and bled the brakes going to bleed the clutch, the works. But I'm trying to figure out what the previous owner did with the after market radio. I wire it a little better (will probably ask later for help with the amp), and I see this bulb socket sticking out the right side. I unscrew it pull it in put a bulb I had it but I have no idea where this baby goes
So I put my finger up the left side and i thought i felt another bulb socket but it turns out to be these two
So I have no idea where these go either to be honest, wiring definitely isn't my strong suit, i was just worrying about over hauling this in a few months maybe add some dual side pipes but want to get it to at least where it needs to be first. Any help would be great.
Old Aug 10, 2016 | 09:11 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Replaced this bulb don't know where it goes😭
The 2 connectors look like they are for the hatch release switch.
Old Aug 13, 2016 | 04:05 PM
G.Penrod's Avatar
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
If it was from under you shifter you probably don't need it. In my automatic it is used to backlight what gear I'm in when shifting. Unless you have something behind your stick that needs backlit, you shouldn't need it.
Veaceonee
Nov 9, 2019 10:52 AM
Eric-86sc
Apr 17, 2016 07:43 PM
maroe624
Apr 12, 2016 01:45 PM
Tony P
Apr 3, 2016 05:19 PM
mfp189
Mar 22, 2016 07:09 PM
