Trunk not closing without adjustments each time.
Old Aug 15, 2016 | 11:49 PM
ryleeman54's Avatar
I have an 87 Iroc Z28 and my pull down motor for my trunk works perfectly fine, but everytime when it comes up i have to pull the motor forward a bit so that it latches on. Is their a fix for this?
Old Aug 17, 2016 | 08:13 PM
G.Penrod's Avatar
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
Re: Trunk not closing without adjustments each time.
If your plastic part is broken anywhere it could cause it to slip. I'd take out the motor and look it over. Hawk's has replacements:
http://www.hawksmotorsports.com/cama...-housing-only/
Old Aug 23, 2016 | 12:31 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Does the center of the hatch align with the side spoiler pieces or it is shifted forward?
Lon
Old Aug 23, 2016 | 01:11 AM
ryleeman54's Avatar
When the motor comes back up it does not come forward all the way. It stays back a little too far
Old Aug 23, 2016 | 01:51 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Sounds kind of like the nylon tracks that the latch slides in the track with might be missing/damaged. This would cause the hatch to flop back and forth towards the front of the car. Pull the plastic trim and check to see if the nylon bits are still in the tracks, if not, lonsal sells them.
Old Aug 23, 2016 | 08:01 AM
lonsal's Avatar
Agreed with replacing the guides if they are broken. They are important in keeping the latch assy aligned and working properly. Here is a link to them on my web site:http://www.top-downsolutions.com/hat...o-or-firebird)
Lon Salgren
KMK454
Apr 14, 2016 04:17 PM
Waco
Exterior Parts Wanted
Apr 7, 2016 10:19 AM
SuziQ305
Mar 31, 2016 08:59 PM
leirch
Jan 9, 2001 09:33 PM
leirch
Dec 11, 2000 02:26 PM
