87IROC factory body stipes? go or stay?
Guys, my 87IROC has the factory color of victory red(real awsome deep red). Well it also has the black and gold stripes on it.
Do you guys think i should keep the stripes or peel them off? I think they look a little tacky. Could get a vote of yes or no to take them off?
I haven't uploaded a pic of the car anywhere yet but you can see a copy of my iroc on any camaro site probly... Its a very popular color combo.
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Brendan
I personally like the stripes. If you remove them, you should also remove IROC-Z from the door. I have never liked the monochromatic look. To me, the stripes break it up a little and add a touch of detail.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
thanks for everybodies thoughts on this one.
Scott has the same color scheme that i have on my car. I don't know, i like the iroc-z image but i think the stripes are coming off. i don't think it looks too out of balance with just the iroc-z logo
hey my car is an 87 iroc, and is the same color u described, but my striping was black and silver, i took it off, except for the iroc-z door logos and i think it looks great. just my opinion but ddo whatever u like.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
same here but my cars black, no stickers but definetely keep the IROC-Z, not only does it look better i think but i didn't have to spend the $$ to get new ones put on
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
90 IROC 5.7l (L98)
LIKE A ROC
colton_carlson
Mar 8, 2019 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
