Has anyone installed leather insert in Firebird door panel?
Old Nov 1, 2016 | 06:25 PM
siuol's Avatar
Car: 1987 Firebird Formula
Engine: Carbureted - 305
Hi,
I am thinking of getting my seats recovered in a different color and would like to change the door insert with the same material. The door panel inserts are bonded to the plastic door panel. I cant see any way of changing the insert without making a mess. Has anyone done this or had a shop do it.
See photo:
Louis
Old Nov 2, 2016 | 03:29 PM
rac's Avatar
rac
Car: Trans am 1987 ×2
Re: Has anyone installed leather insert in Firebird door panel?
I cut thin alu panels and glued on syntetic leather, i also dressed my hedliner whith the same material after some polyester reinforsment.
Attached Thumbnails Has anyone installed leather insert in Firebird door panel?-20160328_202740.jpg   Has anyone installed leather insert in Firebird door panel?-20160328_202650.jpg
Old Nov 2, 2016 | 06:10 PM
siuol's Avatar
That looks very nice. Did you take the insert material off before you mounted the new panel. what did you screw it into. I have not had the door off so I assume its just cardboard backing.
Thanks for taking the time to reply.
Louis
Old Nov 3, 2016 | 11:23 AM
rac's Avatar
rac
The original material is not possible to take off, my alu panel is just screwed on the original door panel which is made of masonite.
Old Nov 6, 2016 | 08:18 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
They look very nice
