Changing upper trim door panel
Old Jan 7, 2017 | 08:47 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
HI all,
I am replacing the upper trim of my door panel. It appears that there are retainers holding the door panel to the trim on the back side. My questions are:
1- are the retainers glue into place or can they be removed without breaking the stud?
2- if they are removable, can I get them somewhere?
3- can otherwise the trim be attached to the door panel somehow?
Any suggestions appreciated!
Thanks.
Old Jan 7, 2017 | 10:40 PM
Drew's Avatar
Re: Changing upper trim door panel
They're pushed on. You can try threading them back off, but you'll probably break a few of the plastic studs.
Old Jan 8, 2017 | 08:46 AM
podiatra's Avatar
Engine: 350 swap
Do you think the trim will stay somewhat in line with only few studs?
Old Jan 8, 2017 | 09:46 AM
siuol's Avatar
Car: 1987 Firebird Formula
Engine: Carbureted - 305
They used reverse socket retainers. I took an old 3-1/8 socket and ground the outside down to 5 sides and it removed them with no problem. When you put them back, reverse the clip so you can get a wrench on it. If you break some studs. align the top perfectly and use some JB weld. There will be enough room back there for reversing the clips.
Louis
Old Jan 8, 2017 | 09:55 AM
podiatra's Avatar
Engine: 350 swap
super, actually I do have the 3- 1/8 socket.
Old Jan 10, 2017 | 06:23 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Louis
Mine needs one of these trims replaced.
Not quite following what you're posting. I hope you can take some pictures along the way to share here.
Old Jan 10, 2017 | 07:05 PM
siuol's Avatar
I am sorry guys, I made an error when I mentioned socket size, its 3/8 inch not 3-1/8.
On this photo of the clips used on the firebird doors, not sure about the camaro. You will note that the clip is reversed to save space between the door panel and the door. The clip is hard spring steel and the screw portion is soft black plastic. You will note that the inside of the clip has 5 sides. I took a 3/8 inch socket and ground down the outside of the socket to form 5 sides. You can then put the socket over the plastic screw and unscrew the clip from the door panel. Don't try to pry the clip off, you will break the plastic screw. If you manage to screw something up, use JB Weld to hold it together.
I hope this helps.
Louis
Old Jan 10, 2017 | 07:38 PM
DynoDave43's Avatar
Yup. Now I get it. And that's more of what I would have expected, design-wise. Thank you.
Old Jan 10, 2017 | 08:13 PM
podiatra's Avatar
Engine: 350 swap
Yep, very cler and thanks for the pic and clarification!
Old Jan 11, 2017 | 07:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
IIRC,there is enough space at the top where you can use Gorilla or Duck tape to keep the panel and upper trim pretty secure.
Old Jan 11, 2017 | 10:37 PM
podiatra's Avatar
Engine: 350 swap
Do you mean the space between the bottom of the trim and where the panel overlap?
Old Jan 12, 2017 | 07:49 AM
mantaguy's Avatar
Engine: 5.0 EFI
Yes.on the backside.
Old Jan 12, 2017 | 07:56 AM
podiatra's Avatar
Engine: 350 swap
got it thanks!
Old Jan 12, 2017 | 08:08 AM
mantaguy's Avatar
Engine: 5.0 EFI
I used Gorilla Tape on mine when I replaced my upper rails,it's holding up very good after about 5-6 years.Good luck.
Old Jan 14, 2017 | 03:37 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
On the speednuts (I think they are called) I just used a pair of pliers and gripped the outer edge of them and screwed them off. I was very careful and didn't break any of the plastic studs.
Then to put them back on, I did what Siuol did and flipped the speednuts over, and used a regular socket on them. Worked very well, and they are nice and tight.
Old Jan 14, 2017 | 02:42 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
They actually make a tool for these. Thanks to this board I found that out a few years ago. I'll post it again in case others are interested.
store.snapon.com/Door-Handle-Trim-Pad-Trim-Nuts-Palnut-Driver-Door-Trim-P643267.aspx
The link won't work. Copy and paste to address bar.
Old Jan 15, 2017 | 10:30 PM
podiatra's Avatar
Engine: 350 swap
Got it done yesterday. I put a little bit of wd40. Use pliers and screw them off. When replace screw them back in . I broke one stud, but panel is nice and tight with remaining ones.
Old Jan 15, 2017 | 11:55 PM
Drew's Avatar
For that kind of money, a person could be forgiven for milling a cavity in a normal hex bit.
Old Jan 16, 2017 | 12:31 AM
On Probation
Podiatra, good for you! Do you have any pics of the final product? Love to see it.
