Best year for a tilt steering column?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
The shift interlock is messed up in my 86s column that's a non tilt wheel so IV decided to pull it and upgrade to a new tilt wheel. Since I don't have vats what's the best car for me to hunt down for a proper column?
Engine: L31 350
Car: 1989 GMC Sierra
Re: Best year for a tilt steering column?
I think the early columns had some minor differences, hopefully someone else will chime in if the earlier columns will fit with changing something minor.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Earlier column is no good due to the Wiper Motor wiring that runs thru it. The 82-83 Wiper system was different than all other Thirdgens.
Pretty sure the 88-89 Columns should work too. If they have SWC or VATS you just don't connect that wiring. IIRC the 90-92 will also work,...... ONLY if the wiper plug at the base of the column is re-pined.
I've got a couple decent tilt columns that would work in your 86,.. .one has a Grant wheel hub already installed on it. if you can't find one local feel free to send me a PM for info.
Engine: L31 350
Awesome ! Finding bigger stuff local is always cool because you avoid the RIDICULOUS shipping expenses that way. The fact that is had a key is beyond lucky too! Glad to hear that you're 'good-to-go' !!
Engine: L31 350
iv luckily got a few yards around me that have a small stockpile of third gens so parts are plentiful.
Engine: L31 350
Engine: L31 350
[QUO awTE=evilemokid94;6110274]The shift interlock is messed up in my 86s column that's a non tilt wheel so IV decided to pull it and upgrade to a new tilt wheel. Since I don't have vats what's the best car for me to hunt down for a proper column?[/QUOTE] working on putting this colum in and I'm having issues getting the shifter interlock cable into the ignition switch. Any recommendations?
