Can someone please help me with my dash?
Car: 1992 Chevrolet Camaro RS
Engine: 5.0 (305)
Hello my name is John I have a 1992 Chevrolet Camaro RS. I am having problems with my dash. When I start and drive the car the dash lights come on and everything works except the oil pressure gauge(not hooked up) and my fuel gauge goes up alittle. Then when I turn my headlights on all of my gauges cut out but the panel lights up still. Can someone please help me. Thank you in advance.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Can someone please help me with my dash?
Is this an unmolested stock car or a modified car (what has been altered) or a trashed car where the wiring is birds'nests with multiple splicing?
Of the top of my head I would say you it sounds like a bad connection. Do all of the interior and exterior lights and devices work normal even when the dash is having issues? It's probably an issue on the power side as opposed to the negative side.
Engine: 5.0 (305)
Car: 1991 Z28 Vert
If it worked fine before you changed engines then it may be just a loose ground at the back of one of the heads or firewall. Could also be a ground that isn't connected.
Car: 1991 Z28 Vert
Did you change the wiring harness in the engine bay or alter it? Again, I would double check all the ground connections on the back of the heads and firewall. Look for any dangling wires.
turboguard
Mar 11, 2017 07:10 PM
