Hi there. New to this site, but have been creeping it. I have been doing some custom work on my 91 formula and this is what I come up with using parts from a 09 g6 and a 4th gen firebird for door panels so far. Whacha think?
I'm going to be using some new weather stripping for the top left. I test fitted with the chunk from the old weather stripping trimmed down a little , it seemed to fill it. Other than that I am debating whether or not to wrap the door card in black carbon fiber vinyl or wrap it in leather
Same here. I'm making my own right now also but mine will be more traditional hot rod style than your path. Blind pleats on the top and carpet on the bottom.
Nice idea. I also wanted to do a dash swap with a 4th gen dash, but after the work I put into my cars dash, switching it to led and fixing some wiring issues it had, I think I would rather keep it.
I have also been looking into ideas for a custom center console
I think the firebirds lend themselves to making from scratch a center console more easily than the Camaros. If you did a 4th gen dash I would just keep the 4th gen center console. I tried making my own center console but found that the only way to do it would be to weld a skeleton or frame out of metal and then attach panels to it.
I have some new door panels as well that go to..(from what I heard..an 88 Camaro Sport Coupe)..and I wanted to install them in my Iroc Z. problem is, they have a cut out for adjustable manual windows, and mine are automatic. will they be able to work or not?
