Gear replacement for Odometer / Tripmeter
Old May 10, 2017 | 12:51 AM
GXP's Avatar
GXP
Car: 1991 Trans Am
Engine: 350 Crate
Transmission: 700R4 with shift kit
Axle/Gears: 10 bolt 2.73
Recently my odometer and tripmeter have stopped working in my 91 TA. It's the electronic speedometer version. My speedometer works fine though. Please try to bear with me as I only took one picture:
There were two worm wheels on the circled shaft that rotated off of the worm gear on the output shaft of the motor coming from the speedometer. These were were broken and seized. I was wondering if there was any way to remove the circled shaft to replace the gears, and if there was anyone who sold replacement gears?
This is for a 120 MPH car by the way
Old May 10, 2017 | 06:29 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Gear replacement for Odometer / Tripmeter
Read this thread:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Old May 10, 2017 | 09:44 AM
Drew's Avatar
There's a thread here somewhere about a replacement gear for the Firebird cluster that you can order. I don't have time to find it right now, but try google.
Drew's Avatar
https://www.shapeways.com/product/KA...FQsIaQodErkHqA
Old May 10, 2017 | 02:44 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
WOW can't believe someone actually makes this!!! Has anyone verified if it works on 1990-92 Camaros? My odometer and trip meter work approximately 10% of the time.
Old May 10, 2017 | 04:32 PM
GXP's Avatar
GXP
Car: 1991 Trans Am
Engine: 350 Crate
Thank you so much for the links Drew and sonjaab. I'm still not seeing much in the thread though about actually replacing it. Do I have to break off that rod to get the gear back in?
Old May 10, 2017 | 08:34 PM
Drew's Avatar
You need to read the thread about fixing the Firebird cluster. https://www.thirdgen.org/forums/inte...roken-but.html
I wouldn't count on the gear I linked above fitting a Camaro.
