Rear hatch alignment help please!!!
Old May 17, 2020 | 10:01 PM
  #51
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Re: Rear hatch alignment help please!!!
Originally Posted by jczoka
I ended up drilling new holes. Because I had already painted and installed the trim pieces a month before I did the hatch re-alignment, and didn't want to scratch them up. Next time I will try to close the gap up. But I don't know what it will take to get the alignment right. A lot of angles involved. I'm convinced that the gap is from the lower hatch shift on the glass. Please post pics if you end up doing this process. I know a lot of us could learn from it.
I need to paint my glass trim as well. Yours look good. What was your process? Did you remove them from the glass or paint them while still on the glass?
Old May 18, 2020 | 12:17 AM
  #52
jczoka's Avatar
Car: 1991 Z28 5spd
I removed them. The glue was all dried up and they came off pretty easy. It was much easier than masking the whole glass. I just used a semi gloss black.
Old May 18, 2020 | 04:28 AM
  #53
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Did they fit tight when you reinstalled them? Did you use an adhesive?
Old May 18, 2020 | 08:02 AM
  #54
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Originally Posted by DaveyDug
I'm in the middle of adjusting my deck lid, and there's something that doesnt make sense. If I adjust the lid to glass position so that the three sections of the spoiler are aligned, the two screw holes on each side of the wide section of the glass trim (shown in this picture) will be in the wrong positions.
I could drill new holes for the screws, but that obviously means things wouldn't be back in the factory positions. I see there is a gap between the two ends of the trim piece at the top center of the glass. It seems to me like this must mean the decklid being pushed back by the struts caused the trim to separate and move back as well.
If all this is true, is there a way to push the trim back together so that the holes will line up again, or will I have to drill new holes and leave the gap as it is?
You have to loosen the glass to hinge bolts/nuts (1 side at a time) then gently tap the black trim forward into place. You probably have a gap in the trim at the top center of the glass, that will be closed up and screw holes will line up better when you get it correct.
86Lucille
Jun 1, 2019 11:48 PM
factory89tpi
Aug 21, 2016 10:08 AM
gholian
Nov 15, 2006 06:24 AM
aaron7
Apr 4, 2004 07:07 PM
