remove shift knob? camaro z28 E 82
Old Sep 26, 2017 | 09:34 PM
rubber-duck's Avatar
remove shift ****? camaro z28 E 82
remove shift ****?
How do you remove the shift ****? has pulled and twists, nothing happens. Is there a magic trick, grateful for the help
Old Sep 26, 2017 | 09:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: remove shift ****? camaro z28 E 82
Pull the button out. Down in there you will see a circlip with holes on the ends for you to place the pointed ends of your circlip pliers in to compress and remove it with. Ball then comes freely up from the shaft.
Don't twist it , you could break off a locating tab that keeps the **** from spinning. You'll see when it comes off what I mean
Old Sep 28, 2017 | 12:26 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Did that work OK for you?
Old Sep 28, 2017 | 01:12 PM
i havet not hade time to check , i'm going to work on my car saturday. that's good clue you gav me
Old Sep 29, 2017 | 07:27 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You need to have a pair of "snap ring pliers" in your tool box!
