A Pillar gauges
Old Oct 31, 2017 | 01:59 PM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
A Pillar gauges
Hey guys, My wide band O2 sensor is on its way out, and if i buy another i might as well buy a gauge set seeing i want a fuel pressure gauge anyway. Im on the fence between a 2 gauge pillar and 3 gauge pillar. Looking for pictures/input. Thanks.
Old Oct 31, 2017 | 09:03 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Re: A Pillar gauges
I am currently running a three gauge pillar, but would suggest your selection of wide band gauge should determine how many holes you go with.
With a change in my build I am currently replacing my nitrous with boost, however with the new AEM wide band it has a pressure boost input as well, so could have gone down to two. Already had the three gauge pillar, so will use the AEM Boost input for logging purposes.
Old Nov 1, 2017 | 09:32 AM
Car: 86' IROC
Axle/Gears: 3.45
Re: A Pillar gauges
Thats awesome. Pretty much what im looking for! I dont want a ton of gauges hanging in my face! Can you select it on the fly to switch the display from boost to a numerical AFR value?
Old Nov 1, 2017 | 09:33 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: A Pillar gauges
Dan, i have the triple pillar gauge in mine, i love it.
Old Nov 1, 2017 | 04:21 PM
Car: 86' IROC
Axle/Gears: 3.45
Re: A Pillar gauges
Got any pictures chris? How close is it to the dashboard? I heard it touches at the lower cluster?
Old Nov 2, 2017 | 08:59 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: A Pillar gauges
I grafted a single universal piece to the pillar.Thats about all i could stand to have on there though.
Old Nov 2, 2017 | 10:02 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Re: A Pillar gauges
Couple more for you of the three cluster. It fully engulfs the stock pillar cover, so looks factory. Although it is tight, dash pad can be removed with cluster in place.
It looks intimidating in the picture from the drivers seat, but really goes unnoticed once driving. I find you have to look for the gauge when spirited driving has your focus.
