Torx Bolt Size?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Torx Bolt Size?
Ftx50 Or could be a ftx500
Engine: Lb9
Transmission: M20
Re: Torx Bolt Size?
Snap on makes the ftx50
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Torx Bolt Size?
T-50
I bought a set of Sears Craftsman for my seat belt reciever search.
Less than $20 bucks.
I figured lifetime guarantee (at the time) and figured if I snapped
one I would get a free replacement.
Car: '89 Firebird
Engine: 7.0L
Re: Torx Bolt Size?
I don't normally buy tools at Autozone but their 3/8 socket Torx bits work really well. Far less slipping/stripping than what I experience with Craftsman.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Torx Bolt Size?
When you're working with torx (especially those seatbelt ones) bolts be sure the inside of the torx head is clean, put the socket on and give it a tap or two with a hammer.
Car: '89 Firebird
Engine: 7.0L
Re: Torx Bolt Size?
And the torque spec is 31 lb-ft, not nearly as tight as you might think. I remember putting a lot of muscle into it when I was young and stupid. Now I actually pay attention to torque specs.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Torx Bolt Size?
Tryin' to remove them in these snowland rustbuckets and u can
snap a t-50 bit like nothin'!
Been there and done that!
Car: `86 SS / `87 SS
