ACC carpets vs Stock Interior carpets
Old Feb 11, 2018 | 01:44 PM
wisemanz28's Avatar
I see a lot of you guys have used ACC for your carpet but not many using Stock Interiors, I'm leaning towards Stock Interiors. Just wanted some feedback about either company.
Old Feb 11, 2018 | 01:53 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: ACC carpets vs Stock Interior carpets
It's all made by ACC and there are several distributors. I like to buy from http://automotiveinteriors.com .
Old Feb 11, 2018 | 02:19 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Very happy with/ACC, replacement in Black, fit great, very little trimming n I punched out holes for seats n belts.
Old Feb 11, 2018 | 02:26 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I put ACC carpeting with mass backing in my car and like it, good quality and was a nice fit with the exception of a couple areas.
Old Feb 11, 2018 | 02:27 PM
wisemanz28's Avatar
Checked out Automotive Interiors T.L. I like their price but they don't offer floor mats.
Old Feb 11, 2018 | 02:35 PM
wisemanz28's Avatar
I compared ACC vs Stock Interiors price wise and for the same carpet (stye, color, and floor mats) Stock Interiors was $250 bucks cheaper.
Old Feb 11, 2018 | 07:16 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I got my carpet from stock interiors with the mass backing. Loved it. Great quality and everything fit amazing
Old Feb 11, 2018 | 07:41 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
I’m having a heck of a time getting my acc mass backed carpet to fit in my 85 ta had to widen the console cutout and I’m having a hell of a time getting it forward enough.ive built this whole car and this is one of the toughest jobs yet.i was wondering if I got the correct carpet.
Old Feb 11, 2018 | 07:56 PM
Ct1987's Avatar
I put an ACC carpet in my 87 formula. Just ran into one problem. I just could not get it under the radio pod. So I split the carpet from the top of the console opening all the way and it ended up having two flaps. It was then easier getting it under the radio pod. The cut is under the console and the radio pod so you do not see it. Other than that it was a perfect fit. It does help to do this job when the weather is warm so you can lay the carpet out in the sun to soften it up. All in all , it took a full day.
Louis
Old Feb 11, 2018 | 07:57 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
from my experience no carpet is going to just drop right in. There's a lot of trimming and making the console hole fit right. What I did was lay the new carpet out in the sun and then get all the shapes pushed out right. Then lay the old carpet on top of the new carpet and cut it out but cut it out to big that way you can make it fit perfect. My carpet from stock interiors was bigger in all directions which is to let you trim it perfectly
Old Feb 11, 2018 | 08:52 PM
Drew's Avatar
Rock Auto has the cheapest prices I've seen on ACC carpet. For the entire carpet set, with shipping, Stock Interiors (www.stockinteriors.com) is $116 and change higher than Rock Auto.
Weird.
Old Feb 12, 2018 | 06:10 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Weird.
I bought mine from RockAuto because of that reason.
Old Feb 12, 2018 | 06:47 PM
wisemanz28's Avatar
Priced out Dove Gray at ACC , Stock Interiors, and RockAuto, RockAto beat the others easily
Old Feb 12, 2018 | 07:30 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
So is the factory style carpet the cutpile? I see there is a Essex line that is more plush but that is probably an upgrade over stock. The Essex with mass backing is around $400. I also have the rear locking cover so I would have to order some by the yard to cover that. I know you can do that with Stock Interiors. BOSE system too but I know I can get carpet for that too through Third Gen Ranch I believe it was.
Old Feb 13, 2018 | 07:00 AM
82tarecaro's Avatar
Get all the carpet from the same place. If you buy it from different places, it will not look the same. Even carpet from the same manufacturer, made at different times will have shading and color differences. I ordered my carpet from 1A auto and asked them to have all the carpet cut from the same dye lot.
Old Feb 14, 2018 | 02:10 PM
T.L.'s Avatar
Those Rock Auto prices are impressive...
Old Mar 4, 2019 | 09:01 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Sorry to dredge up an old thread but to any that have purchased their carpet from Rockauto. Does the passenger cabin carpet come with new “loose fill” (jute) padding as well or is it only the carpet itself?
Old Mar 5, 2019 | 01:37 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
Bought mine last year for a '91 Trans Am, and it had jute on the back, both passenger and driver side. Mine was the kind without the mass backing, just carpet and jute.
Old Mar 5, 2019 | 06:00 AM
Benc1's Avatar
Anyone with info on the carpet with mass backing?does it come with jute padding as well?
Old Mar 5, 2019 | 07:18 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I bought the ACC from Rock auto for my 91 GTA and a different GM vehicle with the mass backing. Both came with the jute also
Old May 14, 2019 | 09:16 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Hey, I'm about to order carpet for my Trans Am as well and I was leaning towards Rock Auto. I asked their support people if the essex carpet with mass backing has jute padding (none of their carpet listings seem to reference jute padding at all), and they basically couldn't answer for sure one way or the other. You ordered recently from rock auto and your mass backed carpet came with the jute padding? Did you get the cutpile or the thicker essex carpet?
Old May 15, 2019 | 09:39 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I got the Essex for my GTA years ago and it had the jute on the back. I more recently ordered the Essex for my 69 Suburban, two or three years ago, and it also had the jute.
Since it is ACC, you should just call them instead of Rock, as they are just a re-seller if you have questions.
Old May 15, 2019 | 10:10 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
It sounds pretty promising then. Contacting ACC to confirm is a very good idea, I’ll do that today. Thank you!
Old May 15, 2019 | 10:33 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
I just called ACC and they said it does include jute padding that will be loose in the box. I’ll be placing my order tonight!
Old May 15, 2019 | 10:49 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
My jute was always glued to the back, not loose, so if they do that now it is a change.
87WS6
Aftermarket Product Review
68
Jan 29, 2026 12:46 PM
1Aauto
Sponsored Vendors
Apr 29, 2009 11:12 AM
tagta1
Mar 17, 2005 07:24 PM
jjcirocz
Aftermarket Vendor Review
May 5, 2002 01:12 AM
