4th Gen power seat wiring
Car: 91 Firbird Formula
Engine: 5.0 TBI
Wiring has never been my best skill. I need some help for a dummy on this.
I have the add a fuse set up to get my power. I understand that end, however I need help at the seat wiring.
1. Is black hot or ground?
2. What do I attach the ground wire to?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 4th Gen power seat wiring
Black is almost always ground, any (sheet)metal is an ideal ground.Best if paint is removed for optimal conductivity.
Car: '89 Firebird
Engine: 7.0L
This is how I wired my seats. Post #309,
https://www.thirdgen.org/forums/ltx-...ml#post5964726
If you pull the carpet back you will find there is a wire grounded to the body under the driver seat. I used that same ground screw for my power seats.
BrianI
Aug 26, 2003 08:44 PM
Eric's85TA
Sep 4, 2002 09:39 AM
