Not the usual shift knob question...
Old Mar 16, 2018 | 07:11 PM
Jayback85's Avatar
Car: 1985 IROC Z w/19D Conteur Int
Engine: LB9 305 TPI
Transmission: MD8 700-R4 Auto
Axle/Gears: GU6 3.42
Not the usual shift **** question...
So lots of threads about how to remove shift *****. I have sort of the opposite problem - how to get it on correctly???
1985 IROC with auto. I can get the **** on, install c-clip, put button back on, but the problem is the **** slides down the post. Is there supposed to be another clip on the bottom side or something to hold it up? Wondering if the inside of the **** originally had a lip or key that would keep it from sliding down that has perhaps worn out? Confused.
I didn't take it off originally so I don't have the experience of uninstalling it to draw on. PO had a B&M shifter on it when I got it, and I am returning it to stock.
Any ideas will be appreciated! Pics even better! Thanks all!
Old Mar 16, 2018 | 09:31 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Not the usual shift **** question...
The shift ball is suppose to have either 1 or 2 small tabs inside to keep it up on the shift lever.If the tabs are not there it will slide down as you already know.
Old Mar 20, 2018 | 11:10 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Funny, in my younger years, I thought that's how they were supposed to be as every one that I had seen had broken tabs and was sitting on the shift plate. Probably one of the reasons they changed the **** a few years later.
Old Mar 20, 2018 | 04:26 PM
JA411's Avatar
Broken line up tab, some one propally tried to twist it off at some point.
JOE
Old Mar 20, 2018 | 05:29 PM
Jayback85's Avatar
Engine: LB9 305 TPI
... thanks gents, i'll have to see if I can rig it somehow.
FirebirdDude88
Oct 10, 2015 08:37 AM
Ex-Ford guy
Apr 6, 2004 04:28 PM
IROC-ZTWENTYGR8
Oct 13, 2000 02:40 AM
