Rear Seat Strike Bolt
Old Sep 10, 2018 | 04:51 PM
johnw999's Avatar
I loosened the strike bolts behind the rear seat, because I thought they needed to come off to remove the plastic trim. That wasn’t necessary. The bolts were wobbly when I loosened them. When I retightened them, one of the strike bolts acted like I stripped the threads. I was trying to tighten to 30 lbs/ft with a torque wrench. It gave, got loose, retightened, gave again with a thud, retightened, etc.. Now I think I may have broke off a welded bolt. Any advice? Is the bolt accessible through the rear tire well?
Old Sep 10, 2018 | 09:42 PM
Drew's Avatar
Re: Rear Seat Strike Bolt
It's a captured square nut. The stamped steel piece around the nut keeps it from spinning. You could try sliding it up or down to reposition it in the stamped riser. You might just get lucky.
Old Sep 10, 2018 | 11:42 PM
johnw999's Avatar
That certainly makes sense! Thanks for the quick reply.
Old Sep 11, 2018 | 07:31 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would pull the screw out first and see if the threads are screwed up first.
Old Sep 5, 2020 | 12:05 PM
johnw999's Avatar
After some work, I got access to the rear bolt. Strike bolt is now secured properly.
383RS89
Oct 23, 2020 02:45 PM
SBlackfoot
Jun 22, 2015 10:10 PM
82camaroWI
Jul 19, 2008 03:15 PM
Diabolical
Jun 25, 2004 11:11 PM
kerryismygirl89
Sep 13, 2003 04:39 PM
