Steering column
Old Sep 19, 2018 | 10:18 PM
Jes212's Avatar
Steering column
Can I use 98 Camaro Steering colum in a 91 Iroc? Are there any know compatibility issues?
Old Sep 19, 2018 | 10:25 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Steering column
Its not a direct bolt in. The snout that connects to the steering shaft is much longer on the 4th gen column.
Old Sep 20, 2018 | 06:11 AM
Jes212's Avatar
Re: Steering column
Thank you for your reply
Old Sep 21, 2018 | 02:27 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Steering column
The steering shaft is also different spline/size I think, I looked at possibly using one as I had a 2k donor car for the LS1 but decided it wasn't worth the effort. So I sold the steering wheel and kept the column just in case I wanted some of the electronics off it. I also looked at using the 4th gen steering shaft and that was a no go.
A lot of the electronics can be used, especially if doing a swap.
I've been looking and I think if I use the wiper controls from the 2k column and other parts then I can use a S10 wiper motor and have all the functions ... but haven't taken the plunge on that yet. The huge wiper motor is very tight with the LS1 engine.
If your column has play in the tilt adjustment though, you can take the steering wheel off and tighten two bolts and solve it. So unless someone tried to hotwire your car there is little reason to swap it.
Camaro kid97
Sep 18, 2014 01:18 PM
SLAYER6669
Jul 31, 2005 10:29 PM
SLAYER6669
Jul 24, 2005 04:16 AM
