Fitting rear hatch struts
Old Oct 11, 2018 | 10:52 AM
jomalley1234's Avatar
Car: Firebird
About to fit new hatch struts as mine won't hold the hatch open anymore. Do i need to be aware of anything when fitting them? are there any torque specs i need to follow or just do the fittings up tight? thanks guys
Old Oct 11, 2018 | 10:58 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Fitting rear hatch struts
if you have rear defrost make sure you get the right ones with connections
Other then that, nothing really special. Torx head I believe. Just tighten them up.
It doesn't take two people, but it does help having someone to help hold the lid up while you replace them.
Old Oct 11, 2018 | 11:32 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If you're not getting Delco replacements, make sure that your rear defrost still works after installing them. I had problems with several off-brand replacements that I tried, they would immediately fry the rear defrost relay/switch as soon as I hooked them up.
Old Oct 11, 2018 | 02:16 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Which struts did you go with?
Old Oct 11, 2018 | 03:21 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IIRC some hatch struts are option specific. If you've got a large factory "wing" on the hatch ( wrap-around Trans Am or 91-92 Z28 high rise ) or maybe a rear window wiper the hatch struts will probably need to be specific for that application. If you buy a generic hatch strut than your probably going to get --- a generic hatch strut. Probably not strong enough for any hatch mounted options and probably not rear defroster style.
Old Oct 11, 2018 | 08:23 PM
Drew's Avatar
Prop open the trunk lid with a broom handle, wood dowel, or whatever.
Loosen the screws at the decklid first, otherwise if you remove the bolts toward the front first, they tend to bind. Easier to take the decklid screws out first, slip the end of the strut off, and take all tension off the front bolts.
Most of the hatch struts are somewhat universal anymore, as in it'd probably be much more difficult to find the struts without the defroster tabs than the other way around.
You'll see listings for struts for with Spoiler, or with Wiper, or with Spoiler and Wiper. From my perspective, it doesn't matter much... The stiffest strut will get soft over time anyway. If you have a heavy wrap around wing, or rear louvers, you'll want the struts listed for cars with all the options. Even then, they might be a bit softer than you expect.
Old Oct 15, 2018 | 02:54 AM
Car: Firebird
Got the struts from lift support depot. they are strongarm ones. i have the lighter 84 spoiler, defrost and rear wiper and they came with all the connections and everything is working fine :-) i did enlist the help of a friend to hold the hatch for me while fitting them and we seemed to do a good job, i now have a hatch that can hold itself up :-) Thanks for the advice guys.
puma1552
Sep 4, 2010 01:16 AM
cwalsh
Sep 20, 2007 05:44 AM
Trux
Sep 2, 2002 12:41 AM
lexussc94
Aftermarket Product Review
Oct 22, 2000 11:54 AM
