Clips/screws for interior trim?
Old Feb 10, 2019 | 12:28 AM
ChelseaHere's Avatar
Car: 86 Camaro Sports Coupe
Engine: 383 Stoker
Transmission: 700R4 transmission
Hi all
I've got trim pieces falling off and I need to find the screws/clips to put them back on. Does anyone know where I can get them or have a picture I can refer to in order to buy some similar ones? I'll attach some pics.
thanks!
Old Feb 13, 2019 | 01:10 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Clips/screws for interior trim?
clips and fasteners should have all the clips you need. you can buy then in bulk bags
Old Feb 14, 2019 | 07:24 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Your local parts store may have most of them in the Dorman/HELP section or try your local auto body supply store.
Fleabay too!
Old Feb 14, 2019 | 01:13 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Hawks has a full interior screw kit... covers most things, the clips are another story I found some of those 25 in one kits on amazon to cover everything but those large plastic screws in the hatch. Hawks has those as well as dorman etc.
Old Feb 14, 2019 | 08:47 PM
Drew's Avatar
I guess I'm not understanding the question. If you're asking what's missing, you're missing the B pillar trim panel, and the speaker cover (sail panel). Looks like the inner 1/4 trim isn't screwed down to the inside of the body, and also the rear trim that goes behind the headliner looks to be missing since it'd somewhat hold the inner 1/4 panel in place.
The screws for the inner quarter are phillips screws about 1" long, self tappers. The speaker covers are held up by the coat hanger which has about a 2" long phillips screw that holds it all tight at the top. The B-pillar trim uses a short phillips trim screw at the bottom, and the top clips into the back of the A-pillar/headliner trim, with a push in retainer like you'd find on the door panels clips into the B-pillar trim and pushes into the inner quarter trim, but honestly that retainer isn't absolutely necessary.
B-pillar trim
B-pillar trims - note screw hole at the bottom, tabs on back side that key to the sheetmetal of the body
1/4 trims, note retainer in one of the panels
Hardware - shortest is for the B-pillar trim, medium is the 1/4 trim, long is the coat hanger screw.
Honestly I'd hit the junkyard for this stuff if I didn't have 20 years worth of pocket screws from junkyard trips. This is literally the kind of thing you put on the counter at the junkyard and they don't even charge you 90% of the time.
beths91camaro
Exterior Parts for Sale
25
May 23, 2019 09:54 AM
mantaguy
May 8, 2012 11:45 PM
Notplayn
Apr 10, 2010 05:16 AM
mbrownone
Interior Parts Wanted
Sep 8, 2006 08:58 PM
JulieGTA
Apr 29, 2003 12:02 PM
