1992 firebird VATS problem
I lost my keys to my car, so I bought new keys with the ignition tum, then I bought the VATS bypass module from eBay, I put a multi meter to the Vats connector going to the car, it's reading 4.67, which is 4600 resistor, so that is what module I bought on eBay, number # 11, but when I turn on the car, dash lights up, security light stays on that tells me the bypass is not working, PLEASE HELP me get her started
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 firebird VATS problem
What sort of bypass did you buy ? One that just bypasses the key cylinder ?
or like this ?
http://www.bakerelectronix.com/products_vats/
or like this ?
Engine: Lb9
Transmission: M20
Btw if you lost your keys how did you determine the vats resistor value ?
Car: 1992 Z28
Engine: 383
You will need a locksmith or someone to test every resistor value on your car to determine what chip it needs. Lost my keys before and had to have someone come out to make a key and test for the correct chip.
or like this ?
or like this ?
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
If you don't care about VATS, get a key cut off your serial# at the dealer (must be a VATS blank), use your original tumbler, and bypass the VATS relay by connecting the power in and power out wires. The relay is behind the kick panel by the drivers foot.
Engine: Lb9
Transmission: M20
this is what I got https://rover.ebay.com/rover/0/0/0?m...2F283284462521
https://www.ebay.com/itm/GM-VATS-Byp...sAAOSwJLJZf7OT
Car: 1989 Firebird
Engine: 5.7 LS1
If you want to keep it all stock one of the easiest ways to do this is get a bag of resistors. There are 15 possible values the key may have. Look here https://www.thirdgen.org/vats_passkey_system/
Here is the catch each test will disable the module for for a few minutes (I usually say 15 min to be safe). So you will need to test a different resistor value every 15 min or so. You can also do this with a potentiometer just use a multi meter to dial in the resistance for each test.
Testing the resistance of the module doesn't tell you anything.
Once you have identified the right resistor value you will need to go to the dealer (or ebay) and buy a key blank with the right pellet and have it cut to match the key that came with your new cylinder. Or use the resistor you found to by pass it.
Or if your really don't care about VATS working buy this https://www.hawksmotorsports.com/vat...maro-firebird/ and follow the install instructions, this will remove the need for a VATS key or a resistor bypass.
Engine: Lb9
Transmission: M20
Here is a bypass like the above but cheaper and I believe it’s duel frequency 30 and 50hz.
https://www.ebay.com/itm/GM-VATS-or-...ss!20876!US!-1
If you state your year make model and engine type I can let you know how to wire it up. Or if you choose reprogramming send me a pm I can assist with that . It’s better to keep a working vats system for vehicle theft especially since it worked before the lost keys. With the bypass you need to jumper the starter enable relay under the drivers side kick panel. The two large gauge wires usually green and yellow otherwise the engine will not crank over.
Engine: Lb9
Transmission: M20
To wire up the vats bypass module from eBay.
you need power. You can get accessory power at the ecm a6
this is a pink and black stripe wire. Then a ground at a12 a black with white stripe wire.
the module signal wire which you will have to try either wire I think ists a 30hz signal hooks to a blue wire at the ecm pin f10.
Engine: Lb9
Transmission: M20
Here is a wiring pinout for a v8. The wires should be at the same location as your v6.
https://tpiparts.net/1227730_pinout_diagram
Engine: Lb9
Transmission: M20
You should contact the seller . It looks to me since this is a duel frequency device you get 30hz out of the white wire if the blue wire is grounded. You get 50hz if the green wire is grounded. Ground the blue wire and cut f10 at the ecm a blue wire and hook the devices white wire to it.I believe that’s what the blue and green wires are for. You can try grounding one wire and try cranking it over if it fires up it’s right. Wait 5 min or so and try grounding the other wire.
just a educated guess but maybe your instructions are better than the eBay schematic.
Dont forget to bypass your starter enable relay pictures on post 14.
https://www.thirdgen.org/forums/elec...pass-vats.html
Engine: Lb9
Transmission: M20
It could be under the tar tape or tucked up under the dash.
https://www.thirdgen.org/forums/tpi/...ay-bypass.html
yes, i went to chevy with my vin number and they made me a key, but they are saying that i have to get the car Programmed, i dont know what they mean by getting the car programmed, has anyone got this done before"?
Engine: Lb9
Transmission: M20
Did you find the starter enable relay?
The passkey module can’t be reprogrammed so they told you false information.
Car: 1989 Firebird
Engine: 5.7 LS1
Sorry had 3ed and 4th gen relay confused in my head. Should have a thick yellow and thick green/white wire.
There is a mat/ sound deading that covers it up under the plastic kick panel that wraps into the door jam.
Car: 1989 Firebird
Engine: 5.7 LS1
That is the ecm, but you will still need to bypass the starter relay in addition to the module. The model just tricks the ecm into thinking vats sees your key otherwise injectors and fuel pump are disabled.
Engine: Lb9
Transmission: M20
That’s the ecm, not sure what 10amp fuse your referring to.
Engine: Lb9
Transmission: M20
Large yellow to large green I think I see them in the picture.
Engine: Lb9
Transmission: M20
Looks like the right relay. If You backprobe or remove the relay. You should have power on the yellow wire if you turn your key to the cranking position.
or ground the yellow with black stripe wire at the relay.
I jumped the starter relay with a small Guage wire, with the gm key when I turn the key to the on, the fuel pump runs and the security light then second later the security light goes off I'm able to turn the car over
Engine: Lb9
Transmission: M20
Making progress, now onto installing the eBay module.
Car: 1989 Firebird
Engine: 5.7 LS1
It could simply be the relay is bad. Does the small black wire go to ground with key in the run position? If vats isn't grounding the relay then the model is failing and I would replace or fully bypass so it doesn't fail at worst possible time. If vats is grounding that wire bench test the relay, and replace it if it's bad. AutoZone can usually show you how to bench test the relay.
Though if unless you just lucked out with the right key resistance I'm surprised the security light is turning off, unless 92 vats is simply the starter disable and not injectors and pump also.
What do you have the ebay module for? If you want it to by pass the vats module, you've already done that. VATS is an old system and it is defeated in less than 30seconds by someone who REALLY wants to steal your car. If you want to keep it bc you are a purist and you want the car all original, than you're gonna have to pay a dealer to fix it. If yo just want to drive the car, properly connect the two power wires that are bypassing the relay and get yourself a proper modern alarm.
Engine: Lb9
Transmission: M20
You should replace the relay and keep the vats system. Like stated above it could be the passkey module not grounding the relay or bad relay or power to the primary side of the relay is missing. This might be a standard spdt relay a google search of any part number on it might help you find one.
https://www.rockauto.com/en/catalog/...ter+relay,3804
Engine: Lb9
Transmission: M20
Car: 1989 Firebird
Engine: 5.7 LS1
I would either fully fix it or fully delete it so you don't have issues in the future. The best solution is to have the eprom in the ECU reprogrammed to disable VATS in the ECU.... Which sounds like maybe a previous owner may have done.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
- Rob
Engine: Lb9
Transmission: M20
I suggested the eBay frequency module. He first got a key after measuring the leads to the passkey module not the old keys because they were missing.
He finally went to the dealer to have them run a vin on the resistance of the missing keys. This was after the module was ordered.
Engine: Lb9
Transmission: M20
Your meter is on the wrong scale. This sounds close to vats #2 key.
In reference to the video, did the engine start and run okay with the old key?
Because it doesn't seem like a vats issue...
- Rob
- Rob
Watch the video I posted, according to everyone, bypassing the starter relay shouldn't make the car start but only turn over the starter and the fuel pump shouldn't come on. I did however took off the wire and put on a new relay i just bought, but car only starts with the wire, hmmmmm. But in the video the fuel pump is priming, i did a fuel pump test, I'm getting 39 psi, should be 46, before I lost the key I started the car every three days for 10 mins, cause I don't drive the car, I do it to let the fuel run threw, one day I went out to start it and it does what its doing in the video, thanks Rob, I was posting this when you was writing that!!!!
