Converting Mechanical speedo to electric.
Old Feb 10, 2019 | 06:50 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
I've done a lot of looking (maybe in the wrong places?) but have been unable to find many people swapping their cluster with mechanical speedo to clusters with a higher mph & rpm.
The only clusters I've found that have 140-145mph speedometers are all electronic speedometers.
Has anyone found the best way to do this using factory gauges? I'm not afraid of wiring and prefer using factory style parts for the conversion.
Old Feb 11, 2019 | 12:53 PM
Abubaca's Avatar
Re: Converting Mechanical speedo to electric.
So you're saying you want to remove your mechanical speedo, and use an electronic speedo? Pretty sure the speedometer gear housing just pops out of the 700r4 and you pop in a electronic speed sensor. Whatever sensor came out of a transmission from the same year as the speedometer you're using. I'd imagine they're all the same....although maybe not.
...or are you saying you want to swap the WHOLE cluster? ...and you're not sure how to wire it? ...that's certainly do-able, but I don't have the info on how. -sorry.
Old Feb 11, 2019 | 01:01 PM
potterc32's Avatar
I would be open to either route. Would prefer to just swap gauges, and add a sensor. Are the tachs interchangeable?
Old Feb 11, 2019 | 01:08 PM
potterc32's Avatar
If I swap the whole cluster, I'll still have to get a speed sensor and everything. I might have to get the pinout diagram for the cluster and move some terminals around to mate correctly with the different model year cluster, that's not the challenge.
After extensive research, I've found that I can get the Dakota speedo interface module, since I don't have the yellow buffer module(which is required for the electronic speedo to work). Had anyone had any experience with this?
Old Feb 11, 2019 | 01:43 PM
GASPEDDLER's Avatar
My car's issue was the opposite of yours. My car was needing to have the factory mechanical speedo communicate with a 4th gen 4l60e. The car is currently running a Dakota Digital ECD-100 ELECTRONIC CABLE DRIVE, the system works well. Not sure if this of use to you but here is unit's paperwork that came with the car.
Old Mar 7, 2019 | 11:03 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
My car (89 GTA) had the electronic speedo and after putting in a TH400 have had some problems with the interface. Am in the process of working with Dakota to streamline the issue and will update as soon as I get a working solution. As far as the speedo goes, I will be using a Canadian one that is calibrated for KMH and reprogramming it for MPH, something to think about.....
Goodolboy0404
Sep 17, 2016 07:26 AM
FireDemonSiC
Sep 7, 2008 04:02 AM
Zrated83
Aug 16, 2007 01:34 PM
iroc-si
Carburetors
Aug 15, 2006 02:26 PM
V6camaroman
May 31, 2004 03:43 PM
