Switch between window switches
Old Mar 9, 2019 | 02:51 PM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
What is the middle switch between the window switches? Is it a lockout for the windows? It doesn’t matter what position I put it in the windows work.
Old Mar 9, 2019 | 03:24 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Switch between window switches
Is your car a convertible? If so, its probably the tonneau release.
Old Mar 9, 2019 | 03:36 PM
Car: 85 Berlinetta
Nope it’s a t top car. Oh and it’s an 85 Berlinetta with the digital dash and pods to control everything if that makes a difference.
Old Mar 9, 2019 | 05:59 PM
88 TA's Avatar
Car: 88 T.A.
Maybe the rear defroster
Old Mar 9, 2019 | 06:02 PM
Car: 85 Berlinetta
Nope that’s the one the whole way at the back. The hatch release is in the middle of all of them and it has an extra small one for fans that was installed by previous owner. I know it has to be factory cause it’s made the same as the others.
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Mar 9, 2019 | 06:04 PM
Car: 85 Berlinetta
Well if it is I’m glad it’s not working! Haha
Old Mar 9, 2019 | 06:14 PM
88 TA's Avatar
Car: 88 T.A.
Can you take a pic from above. Had one in the 80s maybe that will jog my memory
Old Mar 9, 2019 | 06:18 PM
Car: 85 Berlinetta
Will try to get better pic tomorrow. Car is not at my house. There is no marking on it and is a on/off type switch.
Old Mar 9, 2019 | 06:37 PM
my82roc's Avatar
Car: 89 Iroc Convertible
It's either for cruise control or rear wiper.It should not be in between the window switches either.It belongs underneath where you have the hatch release switch
Old Mar 9, 2019 | 06:44 PM
Car: 85 Berlinetta
Ok that would make sense. It did have cruise from the factory. It is no longer hooked up. It has been driving me nuts trying to figure out what it was for. The previous owner also added some sort of switch in the ashtray too. Have yet to figure out what that does. Time to trace the wires I guess. Thanks!
Old Mar 9, 2019 | 08:58 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Turbo boost or smoke screen hopefully. You got K.I.T.T.'s Camaro half cousin.
Old Mar 10, 2019 | 09:27 AM
88 TA's Avatar
Car: 88 T.A.
I was wondering does it still have the swivel radio
Old Mar 10, 2019 | 09:39 AM
Car: 85 Berlinetta
Nope that is long gone.
Old Mar 10, 2019 | 11:57 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yup,... The button with the green LED is to turn on the CRUISE control, (in 84 it was mounted behind the pedestal radio.) It's a great switch to use for any add-on accessories ( TCC lock-up, manual cooling fan control, exhaust cut-out ect. ) because it's a stock button.
What is the aftermarket button next to the hatch release used for ??
Old Mar 10, 2019 | 12:33 PM
Car: 85 Berlinetta
Previos owner put that in for the electric fan. I might have to redo all this and use the cruise button for the fan. The cruise was removed before I purchased the car and I’m putting an aftermarket steering wheel in any way.
gcj280
Mar 9, 2019 06:53 PM
Abubaca
Jan 20, 2011 12:29 AM
trackbird
Dec 9, 2008 09:07 AM
Zepher
Jan 16, 2001 12:06 AM
