Here is the link for a double cupholder I made. It is big as I could get it. The only cutting required is to separate the ash try from the shifter plate.
See all the stains on the floor next to the console? That's why thirdgens don't have cup holders.
Novel solution to the problem, and I suppose that having a cup holder might keep from creating additional stains, but in a perfect world the solution would be to not eat/drink in the car.
If those holes are large enough to hold a plastic bottle ( has a CAP ! ) it's even better still. If not,..... I'd try to enlarge the hole a bit so it holds a soda bottle. As these guys point out - the proximity to the audio gear is a drawback ---> and why I prefer no-mod, bolt-on, side-mounted cup holder over the duel holder design.
That side mount is a great idea. And your double is the nicest I've seen yet.
Would you be interested in a project? I was wanting to use these Autometer angle rings to mount 2 (or 3 if they will fit), 2-5/8" gauges in that ashtray spot and rotated to face the driver. https://www.autometer.com/2-5-8-angl...pack-of-3.html
