82 camaro berlinetta steering colum
Old May 29, 2019 | 11:22 AM
camaroberline82's Avatar
Hi guys I have a 82 camaro berlinetta that has a really bad steering colum I want to know if I can replace it with one from a 87 trans am since I am removing the cruise control thanks in advance
Old May 29, 2019 | 12:02 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 82 camaro berlinetta steering colum
Not directly compatible,...... To simplify things for your repairs try to locate an 82-83 ONLY Steering column.
Old May 29, 2019 | 12:10 PM
Sounds good I’ll try to do that since my 87 trans am steering colum came in a parts car I bought
Old May 29, 2019 | 12:11 PM
Does the model of the car matter or does it only have to be from a berlinetta
Old May 29, 2019 | 12:44 PM
John in RI's Avatar
Most columns are not not model specific,.... ( except GTA ?) so it can be taken from any type of Thirdgen. As long as the donor is an 82 or 83 you should be G-T-G.
Old May 29, 2019 | 12:45 PM
Sounds good thank you
porkyzilla
Dec 29, 2005 12:54 AM
Greg Kuhlmann
Oct 3, 2001 08:42 PM
Greg Kuhlmann
Aug 27, 2001 02:42 AM
Bort62
Dec 11, 2000 11:37 PM
