Urgent: Door Striker Problem
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Does anyone have a pic or the actual part that the door striker screws into? The striker goes through the door jamb and there is a piece with threads in in that fits on the inside of the jamb that it screws into. Mine seem to have taken a walk.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Urgent: Door Striker Problem
No pic, but its a square chunk of steel w/ the threads in the center, about sq.1.5" . Also it has a tendency to fall below the hole on the jamb, because the metal bracket that holds it from falling to the bottom is rather oversize for the threaded chunk.Fiddle around with your fingers just below the hole,you may feel it there.I usually remove the plastic vent above it to reach down and hold it in place while i get the striker started on the threads.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for the reply. I couldn’t remember what they looked like. Need them for my build. Now I just need to find a set.
