Horseshoe shifter for ya third gen.
Old Jul 12, 2022 | 07:20 PM
  #51
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Horseshoe shifter for ya third gen.
Are you gonna rewire for the NSS switch? Wont it rock when its hooked up to the cables? When i connected the shifter/ column cables the shifting got much firmer. Id cut those tall bolts down some.
Looking forward to the finished product.
Old Jul 13, 2022 | 06:29 AM
  #52
FusesTranny's Avatar
The nss is definitely next. The way i have it bolted thru it won't rock. I have washers and lockwashers underneath and on top. But to be 💯 it's an experimental thing. I'm hoping it works out perfect...and I feel u on cutting those bolts down some. The cable I'm still trying to figure out. May have to buy an adjustable one so I won't have a problem. I went to the junkyard to try to find a shift cable with the one I found didn't come close.
Old Jul 13, 2022 | 08:37 PM
  #53
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
You may need a cable from whatever old muscle car that shifter is from. The height of the base from the tunnel is where i feel it could be an issue. With the gap under the base i keep thinking it will rock as you shift into gear. Hopefully not though.
Fronzizzle
Oct 21, 2011 09:33 PM
forklift
May 1, 2006 07:44 PM
redbird8628
Apr 9, 2006 08:39 AM
GodSpeedGTA
Sep 11, 2005 05:47 AM
BOTTLEDZ28
Sep 23, 2001 08:40 AM
