Ignition lock lever delete or disable?
Old Sep 19, 2020 | 04:48 PM
Cadmaro's Avatar
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
Is there a way to delete or disable this silly lever? The one that you must push down to turn the key all the way to the lock position. It annoys me every time I turn my car off and I already have the column partially apart to replace the lock cylinder.
Old Sep 19, 2020 | 05:36 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Ignition lock lever delete or disable?
I know your not gonna be happy with the answer , but , , , , that lever is like the third part you install in the top of the column when building one from scratch , meaning that you'd have to take your column apart to the level seen in this pic to delete the lever .
(The "cutaway" view in the pic is not mine , I shamelessly "borrowed" it from a column rebuild tutorial that for some reason I can't seem to link here)
Old Sep 19, 2020 | 06:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
YAY !!!! I got it to work ..
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
PS , even though the tutorial isn't mine , I used it when I totally rebuilt my tilt column due to a stripped "stub shaft" and the info is spot on , enjoy
Knight Prowl
Oct 1, 2014 04:57 PM
Shribe
Oct 17, 2005 08:57 PM
Kandied91z
Dec 18, 2004 03:40 AM
Zirtbow
Jul 2, 2002 11:50 PM
