Firewall insulation options
Car: 1992 Camaro Z28 Convertible
Engine: LB9
Transmission: T5WC
Axle/Gears: 3:08
I just got started restoring my 92 z28 vert. The mice eat my jute upper and lower firewall insulation. I have seen the lower rubber pad sold online. I've not seen the upper jute pad anywhere. So I would like to know what solutions you guys have come up with. Also what lower pad did you go with? I'm not looking for the cheapest solution. Because this is a money's no object restoration. I want to do it right with the best materials I can get.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Firewall insulation options
You could ask someone to take it out of a car they are parting out, or just buy it in bulk and cut it yourself
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Do a web search for “molded firewall insulation pad” and they show up. It’s a bit pricey and I’m right now in the process of replacing my own. There’s far more to them than just jute padding, there’s a Mylar layer and it has a mass-backing as well to reduce heat and noise.
